By default on installation Flume does not start running immediately. To validate, replace your default conf/flume.conf
with the provdied flume.conf
, restart flume, and see if the data is flowing by examining the destination.
Use this flume.conf
file:
1. Name the components on this agent a1.sources = r1 a1.sinks = k1 a1.channels = c1 2.Describe/configure the source a1.sources.r1.type = seq 3. Describe the sink a1.sinks.k1.type = file_roll a1.sinks.k1.channel = c1 a1.sinks.k1.sink.directory = /tmp/flume 4. Use a channel which buffers events in memory a1.channels.c1.type = memory 5. Bind the source and sink to the channel a1.sources.r1.channels = c1 a1.sinks.k1.channel = c1
After starting flume, check /tmp/flume
to see if there are any files there. The
files should contain simple sequential numbers. After validating, stop flume and
revert changes to flume.conf
to prevent your disk from filling up.
