Using CEMPDF version
Flow designer in CEM
Learn how to build and publish dataflows by using flow designer in the Cloudera Edge Management (CEM) UI.
To navigate to the Flow Designer, click the Design icon (). The Open Flow screen initially appears, as shown in the following image, and displays information about the classes in the system:
To build a dataflow, select the desired class from the table and click OPEN. Alternatively, you can double-click on the desired class. The Design screen appears as shown in the following image:
For more information on how to build a dataflow, see Building a dataflow in CEM. For more information on publishing a dataflow, see Publishing a dataflow in CEM.
The Open Flow screen appears initially when you navigate to Flow Designer. It displays the following information about the dataflows and classes in the system:
  • Status
  • Class
  • Published Version
  • Published On
You can sort data in each column in ascending or descending order by clicking the column name. For example, you can sort the dataflows based on which class they are associated with by clicking the Class column name.
You can also filter the data by class.
The Design screen contains the following segments, each responsible for different functionalities of the application:
  • Components Toolbar. The components toolbar consists of the components that you can drag onto the canvas to build your dataflow.
  • Services. SERVICES are shared services that can be used by processors and other services to utilize for configuration or task execution.
  • Parameters. Provides the ability to parameterize the values of processor and service properties in the flow.
  • Actions. Use the ACTIONS drop-down to open a different dataflow, publish a dataflow, or revert to the last published version of a dataflow.
  • Flow Status. The Flow Status displays information about the flow including when the flow was published, what was the last published version of the flow, and the status of the flow.
    • Modified (). The flow has been modified since the flow has been published.
    • Current (). The current published version of the flow.
