Anywhere Cloud manages the Kubernetes resources of Cloudera Migration Assistant and reapplies them, so changes that you make to them directly
are undone. Change settings in the engine configuration or on the Feature
Flags page instead.
Symptoms
You change a ConfigMap, a Secret, a deployment, or another Kubernetes resource of a Cloudera Migration Assistant engine instance, for example, by using kubectl. After some time, or
after a pod restarts, the old value is back.
Cause
Anywhere Cloud manages the engines and their Kubernetes resources. It
reapplies the resources of each engine instance from the engine configuration, and reverts
changes that you make to them in another way.
Solution
Find where you can change the setting.
See Settings and environment variables you can use.
Make the change in one of these places:
- The engine configuration of the instance, on the Apps page
of the Anywhere Cloud Console. See Engine configuration: Cloudera Migration Assistant and
Engine configuration: Cloudera Migration Assistant Agent.
- The page of the Cloudera Migration Assistant web interface, for the features that
it lists. See Turning features on and off.
Anywhere Cloud stores passwords and keys in Kubernetes Secrets
that it creates from the engine configuration. See How secrets are stored.
The engine configuration of the Cloudera Migration Assistant Agent engine has these
fields:
Table 1. Cloudera Migration Assistant Agent engine fields
| Field |
Required |
Default |
Description |
| Enable AWC Secret Manager (awcSecretManagerEnabled) |
No |
Off |
Stores the connection credentials of the agent in Anywhere Cloud Secret Service
instead of in the internal keystore of the agent. Turn it on only when the Secret
Service is set up with an external vault. |
| Internal Keystore Password (internalKeystorePassword) |
No |
Generated |
The password of the internal TLS keystore of the agent. It is independent of the
internal keystore password of the Cloudera Migration Assistant engine, which Cloudera Migration Assistant generates
automatically. |
The Feature Flags tab has these features:
Table 2. Feature flags
| Feature |
Key |
Default |
What is displayed when it is on |
| CWO auto-discovery |
cma.cwo-auto-discovery-enabled |
Off |
Cloudera Migration Assistant discovers Cloudera Workflow Orchestrator services
automatically. This feature is in Technical Preview. If automatic discovery does not
work, register Cloudera Workflow Orchestrator manually. See Features in Technical Preview. |
If the setting is not in either place, you cannot change it on Anywhere Cloud.
