The following table lists the default ports used by Ambari Server and Ambari Agent services.
Service | Servers | Default Ports Used | Protocol | Description | Need End User Access? | Configuration Parameters |
Ambari Server | Ambari Server host | 8080 See Optional: Change the Ambari Server Port for instructions on changing the default port. | http See Optional: Set Up HTTPS for Ambari Server for instructions on enabling HTTPS. | Interface to Ambari Web and Ambari REST API | No |
Ambari Server | Ambari Server host | 8440 | https | Handshake Port for Ambari Agents to Ambari Server | No |
Ambari Server | Ambari Server host | 8441 | https | Registration and Heartbeat Port for Ambari Agents to Ambari Server | No |
Ambari Agent | All hosts running Ambari Agents | 8670 You can change the Ambari Agent ping port in the Ambari Agent configuration. | tcp | Ping port used for alerts to check the health of the Ambari Agent | No |
