On the Ambari Server host, stage the appropriate PostgreSQL connector for later deployment.
Install the connector.
RHEL/CentOS/Oracle Linux
yum install postgresql-jdbc*
SLES
Copy the connector.jar file to the Java share directory.
cp /usr/share/pgsql/postgresql-*.jdbc3.jar /usr/share/java/postgresql-jdbc.jar
Confirm that .jar is in the Java share directory.
Change the access mode of the.jar file to 644.
ambari-server setup --jdbc-db=postgres
--jdbc-driver=/usr/share/java/postgresql-jdbc.jar
echo "CREATE DATABASE <HIVEDATABASE>;" | psql -U postgres echo "CREATE USER <HIVEUSER> WITH PASSWORD '<HIVEPASSWORD>';" | psql -U postgres
Where <HIVEUSER> is the Hive user name, <HIVEPASSWORD> is the Hive user password and <HIVEDATABASE> is the Hive database name.
Load the Hive database schema.
For a HDP 2.2 Stack:
Important Ambari sets up the Hive Metastore database schema automatically.
You do not need to pre-load the Hive Metastore database schema into your PostgreSQL database for a HDP 2.2 Stack.
For a HDP 2.1 Stack:
You must pre-load the Hive database schema into your PostgreSQL database using the schema script, as follows:
# psql -U <HIVEUSER> -d <HIVEDATABASE> \connect <HIVEDATABASE>; \i hive-schema-0.13.0.postgres.sql;
Find the
file in the/var/lib/ambari-server/resources/stacks/HDP/2.1/services/HIVE/etc/
directory of the Ambari Server host after you have installed Ambari Server.For a HDP 2.0 Stack:
# sudo -u postgres psql \connect <HIVEDATABASE>; \i hive-schema-0.12.0.postgres.sql;
Find the
file in the/var/lib/ambari-server/resources/stacks/HDP/2.0.6/services/HIVE/etc/
directory of the Ambari Server host after you have installed Ambari Server.For a HDP 1.3 Stack:
# sudo -u postgres psql \connect <HIVEDATABASE>; \i hive-schema-0.10.0.postgres.sql;
Find the
file in the/var/lib/ambari-server/resources/stacks/HDP/1.3.2/services/HIVE/etc/
