On the Ambari Server host, stage the appropriate MySQL connector for later deployment.
Install the connector.
RHEL/CentOS/Oracle Linux
SLES
UBUNTU
Confirm that
mysql-connector-java.jar
is in the Java share directory.ls /usr/share/java/mysql-connector-java.jar
Make sure the .jar file has the appropriate permissions - 644.
Create a user for Oozie and grant it permissions.
Using the MySQL database admin utility:
# mysql -u root -p CREATE USER ‘<OOZIEUSER>’@’%’ IDENTIFIED BY ‘<OOZIEPASSWORD>’;
FLUSH PRIVILEGES;
Create the Oozie database.
The Oozie database must be created prior.
# mysql -u root -p
CREATE DATABASE
<OOZIEDATABASE>Where <OOZIEDATABASE> is the Oozie database name.
