2.2. Using Hive with MySQL
To set up MySQL for use with Hive:
    1. Install the connector.
      RHEL/CentOS/Oracle Linux
      SLES
      # mysql -u root -p
      CREATE USER ‘<HIVEUSER>’@’localhost’ IDENTIFIED BY ‘<HIVEPASSWORD>’;
      GRANT ALL PRIVILEGES ON *.* TO '<HIVEUSER>'@'localhost';
      CREATE USER ‘<HIVEUSER>’@’%’ IDENTIFIED BY ‘<HIVEPASSWORD>’;
      GRANT ALL PRIVILEGES ON *.* TO '<HIVEUSER>'@'%';
      CREATE USER '<HIVEUSER>'@'<HIVEMETASTOREFQDN>'IDENTIFIED BY '<HIVEPASSWORD>';
      GRANT ALL PRIVILEGES ON *.* TO '<HIVEUSER>'@'<HIVEMETASTOREFQDN>';
      FLUSH PRIVILEGES;
    • Where <HIVEUSER> is the Hive user name, <HIVEPASSWORD> is the Hive user password and <HIVEMETASTOREFQDN> is the Fully Qualified Domain Name of the Hive Metastore host.
  3. Create the Hive database.
    The Hive database must be created before loading the Hive database schema.
    # mysql -u root -p
    CREATE DATABASE <HIVEDATABASE>
    Where <HIVEDATABASE> is the Hive database name.
  4. Load the Hive database schema.
    • For a HDP 2.2 or later Stacks:
      [Important]Important
      You do not need to pre-load the Hive Metastore database schema into your MySQL database for a HDP 2.2 Stack.
    • For HDP 2.1 Stack:
      You must pre-load the Hive database schema into your MySQL database using the schema script, as follows. mysql -u root -p <HIVEDATABASE> hive-schema-0.13.0.mysql.sql
      Find the hive-schema-0.13.0.mysql.sql file in the /var/lib/ambari-server/resources/stacks/HDP/2.1/services/HIVE/etc/ directory of the Ambari Server host after you have installed Ambari Server.
