3.1. Using Oozie with Oracle
    2. Select Oracle Database 11g Release 2 - ojdbc6.jar.
    4. Execute the following command, adding the path to the downloaded.jar file:
      ambari-server setup --jdbc-db=oracle --jdbc-driver=/path/to/downloaded/ojdbc6.jar
    # sqlplus sys/root as sysdba
    QUIT;
