Ambari Reference Guide
Default Network Port Numbers - Ambari
The following table lists the default ports used by Ambari Server and Ambari Agent services.
Service
Servers
Default Ports Used
Protocol
Description
Need End User Access?
Configuration Parameters
Ambari Server
Ambari Server host
8080 See Optional: Change the Ambari Server Port for instructions on changing the default port.
http See Configure Ambari Server for Authenticatd HTTP for instructions.
Interface to Ambari Web and Ambari REST API
No
Ambari Server
Ambari Server host
8440
https
Handshake Port for Ambari Agents to Ambari Server
No
Ambari Server
Ambari Server host
8441
https
Registration and Heartbeat Port for Ambari Agents to Ambari Server
No
Ambari Agent
All hosts running Ambari Agents
8670 You can change the Ambari Agent ping port in the Ambari Agent configuration.
tcp
Ping port used for alerts to check the health of the Ambari Agent
No
