Using Hive with Oracle
On the Ambari Server host, stage the appropriate JDBC driver file for later deployment.
Download the Oracle JDBC (OJDBC) driver from http://www.oracle.com/technetwork/database/features/jdbc/index-091264.html.
For Oracle Database 11g: select
Oracle Database 11g Release 2 drivers > ojdbc6.jar
.For Oracle Database 12c: select
Oracle Database 12c Release 1 drivers > ojdbc7.jar
.Make sure the .jar file has the appropriate permissions. For example:
chmod 644 ojdbc7.jar
Execute the following command, adding the path to the downloaded .jar file:
Using the Oracle database admin utility:
# sqlplus sys/root as sysdba
QUIT;
Where <HIVEUSER> is the Hive user name and <HIVEPASSWORD> is the Hive user password.
Load the Hive database schema.
For HDP 2.2 or later Stacks
Important Ambari sets up the Hive Metastore database schema automatically.
You do not need to pre-load the Hive Metastore database schema into your Oracle database for a HDP 2.2 Stack.
For a HDP 2.1 Stack
You must pre-load the Hive database schema into your Oracle database using the schema script, as follows: sqlplus <HIVEUSER>/<HIVEPASSWORD> < hive-schema-0.13.0.oracle.sql
Find the
file in the/var/lib/ambari-server/resources/stacks/HDP/2.1/services/HIVE/etc/
directory of the Ambari Server host after you have installed Ambari Server.For a HDP 2.0 Stack
You must pre-load the Hive database schema into your Oracle database using the schema script, as follows: sqlplus <HIVEUSER>/<HIVEPASSWORD> < hive-schema-0.12.0.oracle.sql
Find the
file in the/var/lib/ambari-server/resources/stacks/HDP/2.0.6/services/HIVE/etc/
directory of the Ambari Server host after you have installed Ambari Server.For a HDP 1.3 Stack
You must pre-load the Hive database schema into your Oracle database using the schema script, as follows: sqlplus <HIVEUSER>/<HIVEPASSWORD> < hive-schema-0.10.0.oracle.sql
Find the
file in the/var/lib/ambari-server/resources/stacks/HDP/1.3.2/services/HIVE/etc/
