Using Ambari with Oracle
On the Ambari Server host, install the appropriate
JDBC.jar
file.Download the Oracle JDBC (OJDBC) driver from http://www.oracle.com/technetwork/database/features/jdbc/index-091264.html.
For Oracle Database 11g: select
Oracle Database 11g Release 2 drivers > ojdbc6.jar
.For Oracle Database 12c: select
Oracle Database 12c Release 1 drivers > ojdbc7.jar
.Copy the .jar file to the Java share directory. For example:
Make sure the .jar file has the appropriate permissions. For example:
Create a user for Ambari and grant that user appropriate permissions.
# sqlplus sys/root as sysdba
CREATE USER <AMBARIUSER> IDENTIFIED BY <AMBARIPASSWORD> default tablespace "USERS" temporary tablespace "TEMP";
QUIT;
You must pre-load the Ambari database schema into your Oracle database using the schema script.
Find the Ambari-DDL-Oracle-CREATE.sql file in the
/var/lib/ambari-server/resources/
Advanced Database Configuration > Option [2] Oracle
and respond to the prompts using the username/password credentials you created in step 2.
