Using Hive with PostgreSQL
On the Ambari Server host, stage the appropriate PostgreSQL connector for later deployment.
Install the connector.
RHEL/CentOS/Oracle Linux
yum install postgresql-jdbc*
SLES
Debian/Ubuntu
apt-get install -y libpostgresql-jdbc-java
Confirm that .jar is in the Java share directory.
Change the access mode of the .jar file to 644.
Where <HIVEUSER> is the Hive user name, <HIVEPASSWORD> is the Hive user password and <HIVEDATABASE> is the Hive database name.
