2.3. Using Hive with PostgreSQL
    1. Install the connector.
      RHEL/CentOS/Oracle Linux yum install postgresql-jdbc*
      SLES zypper install -y postgresql-jdbc
    2. Copy the connector.jar file to the Java share directory.
      cp /usr/share/pgsql/postgresql-*.jdbc3.jar /usr/share/java/postgresql-jdbc.jar
    3. Confirm that .jar is in the Java share directory.
    4. Change the access mode of the.jar file to 644.
    5. Execute the following command:
      ambari-server setup --jdbc-db=postgres--jdbc-driver=/usr/share/java/postgresql-connector-java.jar
      echo "CREATE DATABASE <HIVEDATABASE>;" | psql -U postgres echo "CREATE USER <HIVEUSER> WITH PASSWORD '<HIVEPASSWORD>';" | psql -U postgres
    • Where <HIVEUSER> is the Hive user name, <HIVEPASSWORD> is the Hive user password and <HIVEDATABASE> is the Hive database name.
  3. Load the Hive database schema.
    • For a HDP 2.2 Stack:
      [Important]Important
      You do not need to pre-load the Hive Metastore database schema into your PostgreSQL database for a HDP 2.2 Stack.
    • For a HDP 2.1 Stack:
      You must pre-load the Hive database schema into your PostgreSQL database using the schema script, as follows:
      # psql -U <HIVEUSER> -d <HIVEDATABASE> \connect <HIVEDATABASE>; \i hive-schema-0.13.0.postgres.sql;
      Find the hive-schema-0.13.0.postgres.sql file in the /var/lib/ambari-server/resources/stacks/HDP/2.1/services/HIVE/etc/ directory of the Ambari Server host after you have installed Ambari Server.
    • For a HDP 2.0 Stack:
      # sudo -u postgres psql \connect <HIVEDATABASE>; \i hive-schema-0.12.0.postgres.sql;
      Find the hive-schema-0.12.0.postgres.sql file in the /var/lib/ambari-server/resources/stacks/HDP/2.0.6/services/HIVE/etc/ directory of the Ambari Server host after you have installed Ambari Server.
    • For a HDP 1.3 Stack:
      # sudo -u postgres psql \connect <HIVEDATABASE>; \i hive-schema-0.10.0.postgres.sql;
      Find the hive-schema-0.10.0.postgres.sql file in the /var/lib/ambari-server/resources/stacks/HDP/1.3.2/services/HIVE/etc/ directory of the Ambari Server host after you have installed Ambari Server.
