3.3. Using Oozie with PostgreSQL
    1. Install the connector.
      RHEL/CentOS/Oracle Linux
      yum install postgresql-jdbc
      SLES
      UBUNTU
      apt-get install -y postgresql-jdbc
    2. Copy the connector.jar file to the Java share directory.
      cp /usr/share/pgsql/postgresql-*.jdbc3.jar /usr/share/java/postgresql-jdbc.jar
    3. Confirm that .jar is in the Java share directory.
    4. Change the access mode of the .jar file to 644.
    5. Execute the following command:
      ambari-server setup --jdbc-db=postgres --jdbc-driver=/usr/share/java/postgresql-connector-java.jar
    • Where <OOZIEUSER> is the Oozie user name, <OOZIEPASSWORD> is the Oozie user password and <OOZIEDATABASE> is the Oozie database name.
