Release Notes
HDF Repository Location for IBM Power Systems
Use the following table to identify the HDF 3.4.0 repository location for IBM power systems and operational objectives.
Warning
Warning
If you download and install HDF 3.4.0, you must immediately apply a hotfix to avoid significant production environment complications.
Problem: The Apache NiFi build in HDF 3.4.0 contains a bug which under certain cases will cause the content repository to not properly remove content which is no longer accessible and should be cleaned. Without this hotfix applied the NiFi content repository storage locations could become full and block further operations until the resources are released.
Solution: Contact customer support for information about the available hotfix.
Table 1. RHEL 7 HDF repository & additional download locations
OS Format Download location
RHEL 7 (64-bit): HDF Build Number 3.4.0.0-155
HDF Base URL http://public-repo-1.hortonworks.com/HDF/centos7-ppc/3.x/updates/3.4.0.0
HDF Repo http://public-repo-1.hortonworks.com/HDF/centos7-ppc/3.x/updates/3.4.0.0/hdf.repo
RPM tarball http://public-repo-1.hortonworks.com/HDF/centos7-ppc/3.x/updates/3.4.0.0/HDF-3.4.0.0-centos7-ppc-rpm.tar.gz
Tars tarball http://public-repo-1.hortonworks.com/HDF/centos7-ppc/3.x/updates/3.4.0.0/HDF-3.4.0.0-centos7-ppc-tars-tarball.tar.gz
HDF Management Pack http://public-repo-1.hortonworks.com/HDF/centos7-ppc/3.x/updates/3.4.0.0/tars/hdf_ambari_mp/hdf-ambari-mpack-3.4.0.0-155.tar.gz
HDP and Ambari Repositories
Ambari http://public-repo-1.hortonworks.com/ambari/centos7-ppc/2.x/updates/2.7.3.0/ambari.repo
HDP
http://public-repo-1.hortonworks.com/HDP/centos7-ppc/3.x/updates/3.1.0.0/hdp.repo
HDP-UTILS http://public-repo-1.hortonworks.com/HDP-UTILS-1.1.0.22/repos/centos7-ppc/hdp-utils.repo
