1. Getting Ready to Upgrade
  1. Stop all services (including MapReduce) and client applications deployed on HDFS using the instructions provided here.
  2. Run the fsck command as instructed below and fix any errors. (The resulting file will contain complete block map of the file system.)
    hadoop fsck / -files -blocks -locations > dfs-old-fsck-1.log
  3. Use the following instructions to compare the status before and after the upgrade:
    [Note]Note
    The following commands must be executed by the user running the HDFS service (by default, the user is hdfs).
    1. Capture the complete namespace of the file system. (The following command does a recursive listing of the root file system. )
      su hdfs
      hadoop dfs -lsr / > dfs-old-lsr-1.log
    2. Run report command to create a list of DataNodes in the cluster.
      su hdfs
      hadoop dfsadmin -report > dfs-old-report-1.log
    3. Optionally, copy all or unrecoverable data stored in DFS to a local file system or to a backup instance of DFS.
    4. Optionally, repeat the steps 3 (a) through 3 (c) and compare the results with the previous run to ensure the state of the file system remained unchanged.
  4. As HDFS user, execute the following command to save namespace:
    hadoop dfsadmin -saveNamespace
  5. Copy the following checkpoint files into a backup directory:
    • dfs.name.dir/edits
    • dfs.name.dir/image/fsimage
  6. Stop the HDFS. Ensure all the HDP services in the cluster are completely stopped at this point.
  7. If upgrading Hive, ensure that you back up the Hive database.
  8. Configure the local repositories.
    [Note]Note
    If your cluster does not have access to the Internet, or you are creating a large cluster and you want to conserve bandwidth, you can instead provide a local copy of the HDP repository that your hosts can access. For more information, see  Deployment Strategies for Data Centers with Firewalls., a separate document in this set.
    1. For each node in your cluster, download the yum repo configuration file hdp.repo. From a terminal window, type:
      • For RHEL and CentOS 5
        wget  http://public-repo-1.hortonworks.com/HDP/centos5/1.x/GA/hdp.repo -O /etc/yum.repos.d/hdp.repo
      • For RHEL and CentOS 6
        wget  http://public-repo-1.hortonworks.com/HDP/centos6/1.x/GA/hdp.repo -O /etc/yum.repos.d/hdp.repo
      • For SLES 11
        wget  http://public-repo-1.hortonworks.com/HDP/suse11/1.x/GA/hdp.repo -O /etc/zypp/repos.d/hdp.repo
    2. Confirm the HDP repository is configured by checking the repo list.
      • For RHEL/CentOS:
        yum repolist
      • For SLES:
        zypper repos
