6. Upgrade WebHCat (Templeton)
  1. Remove old Templeton packages. On the Templeton host machine, execute the following commands:
    • For RHEL/CentOS:
      yum remove templeton\*
    • For SLES:
      zypper remove templeton\*
  2. Install WebHCat.
    • For RHEL/CentOS:
      yum install webhcat-tar-hive webhcat-tar-pig
    • For SLES:
      zypper install webhcat-tar-hive webhcat-tar-pig
    Also see the instructions on manually deploying WebHCat instance provided here.
  3. Start WebHCat. On the WebHCat host machine, execute the following command:
    sudo su -l hcat -c "/usr/lib/hcatalog/sbin/webhcat_server.sh start"
  4. Smoke test WebHCat. On the WebHCat host machine, execute the following command:
     http://$WEBHCAT_HOST_MACHINE:50111/templeton/v1/status
  5. Remove shared libraries from old Templeton installation. On the WebHCat host machine, execute the following command:
    sudo su -l hdfs -c "hadoop dfs -rmr -skipTrash /apps/templeton"
    rm -rf /usr/share/HDP-templeton
