1.1. Using Ambari with Oracle
  1. On the Ambari Server host, install the appropriate JDBC .jar file.
    2. Select Oracle Database 11g Release 2 - ojdbc6.jar.
    3. Copy the .jar file to the Java share directory.
      cp ojdbc6.jar /usr/share/java/
    4. Make sure the .jar file has the appropriate permissions - 644.
  2. Create a user for Ambari and grant it permissions.
      # sqlplus sys/root as sysdba
      CREATE USER $AMBARIUSER IDENTIFIED BY $AMBARIPASSWORD default tablespace
      “USERS” temporary tablespace “TEMP”;
      GRANT unlimited tablespace to $AMBARIUSER;
      GRANT create session to $AMBARIUSER;
      GRANT create TABLE to $AMBARIUSER;
      QUIT;
    • Where $AMBARIUSER is the Ambari user name and $AMBARIPASSWORD is the Ambari user password.
    1. You must pre-load the Ambari database schema into your Oracle database using the schema script.
      sqlplus $AMBARIUSER/$AMBARIPASSWORD < Ambari-DDL-Oracle-CREATE.sql
    2. Find the Ambari-DDL-Oracle-CREATE.sql file in the /var/lib/ambari-server/resources/ directory of the Ambari Server host after you have installed Ambari Server.
  4. When setting up the Ambari Server, select Advanced Database Configuration > Option [2] Oracle and enter the information use the username/password credentials you created in step 2.
