2.1. Using Hive with Oracle
  1. On the Hive Metastore host, install the appropriate JDBC .jar file.
    2. Select Oracle Database 11g Release 2 - ojdbc6.jar.
    3. Copy the .jar file to the Java share directory.
      cp ojdbc6.jar /usr/share/java
    4. Make sure the .jar file has the appropriate permissions - 644.
      # sqlplus sys/root as sysdba
      CREATE USER $HIVEUSER IDENTIFIED BY $HIVEPASSWORD;
      GRANT SELECT_CATALOG_ROLE TO $HIVEUSER;
      GRANT CONNECT, RESOURCE TO $HIVEUSER;
      QUIT;
    • Where $HIVEUSER is the Hive user name and $HIVEPASSWORD is the Hive user password.
  3. Load the Hive database schema.
    • You must pre-load the Hive database schema into your Oracle database using the schema script.
    • When using HDP 2.1 Stack:
      sqlplus $HIVEUSER/$HIVEPASSWORD < hive-schema-0.13.0.oracle.sql
      Find the hive-schema-0.13.0.oracle.sql file in the /var/lib/ambari-server/resources/stacks/HDP/2.1/services/HIVE/etc/ directory of the Ambari Server host after you have installed Ambari Server.
    • When using HDP 2.0 Stack:
      sqlplus $HIVEUSER/$HIVEPASSWORD < hive-schema-0.12.0.oracle.sql
      Find the hive-schema-0.12.0.oracle.sql file in the /var/lib/ambari-server/resources/stacks/HDP/2.0.6/services/HIVE/etc/ directory of the Ambari Server host after you have installed Ambari Server.
    • When using HDP 1.3 Stack:
      sqlplus $HIVEUSER/$HIVEPASSWORD < hive-schema-0.10.0.oracle.sql
      Find the hive-schema-0.10.0.oracle.sql file in the /var/lib/ambari-server/resources/stacks/HDP/1.3.2/services/HIVE/etc/ directory of the Ambari Server host after you have installed Ambari Server.
