2.3. Using Hive with PostgreSQL
  1. On the Hive Metastore host, install the connector.
    1. Install the connector.
      RHEL/CentOS/Oracle Linux
      yum install postgresql-jdbc*
      SLES
    2. Copy the connector .jar file to the Java share directory.
      cp /usr/share/pgsql/postgresql-*.jdbc3.jar /usr/share/java/postgresql-jdbc.jar
    3. Confirm that .jar is in the Java share directory.
    4. Change the access mode of the .jar file to 644.
      echo "CREATE DATABASE $HIVEDATABASE;" | psql -U postgres
      echo "CREATE USER $HIVEUSER WITH PASSWORD '$HIVEPASSWORD';" | psql -U postgres
      echo "GRANT ALL PRIVILEGES ON DATABASE $HIVEDATABASE TO $HIVEUSER;" | psql -U postgres
    • Where $HIVEUSER is the Hive user name, $HIVEPASSWORD is the Hive user password and $HIVEDATABASE is the Hive database name.
  3. Load the Hive database schema.
    • You must pre-load the Hive database schema into your PostgreSQL database using the schema script.
    • When using HDP 2.1 Stack:
      # psql -U $HIVEUSER -d $HIVEDATABASE
      \connect $HIVEDATABASE;
      \i hive-schema-0.13.0.postgres.sql;
      Find the hive-schema-0.13.0.postgres.sql file in the /var/lib/ambari-server/resources/stacks/HDP/2.1/services/HIVE/etc/ directory of the Ambari Server host after you have installed Ambari Server.
    • When using HDP 2.0 Stack:
      # sudo -u postgres psql
      \i hive-schema-0.12.0.postgres.sql;
      Find the hive-schema-0.12.0.postgres.sql file in the /var/lib/ambari-server/resources/stacks/HDP/2.0.6/services/HIVE/etc/ directory of the Ambari Server host after you have installed Ambari Server.
    • When using HDP 1.3 Stack:
      \i hive-schema-0.10.0.postgres.sql;
      Find the hive-schema-0.10.0.postgres.sql file in the /var/lib/ambari-server/resources/stacks/HDP/1.3.2/services/HIVE/etc/ directory of the Ambari Server host after you have installed Ambari Server.
