1.3. Using Ambari with PostgreSQL
To set up PostgreSQL for use with Ambari:
  1. Create a user for Ambari and grant it permissions.
      # sudo -u postgres psql
      CREATE DATABASE $AMBARIDATABASE;
      CREATE USER $AMBARIUSER WITH PASSWORD ‘$AMBARIPASSWORD’;
      GRANT ALL PRIVILEGES ON DATABASE $AMBARIDATABASE TO $AMBARIUSER;
      \connect $AMBARIDATABASE;
      CREATE SCHEMA $AMBARISCHEMA AUTHORIZATION $AMBARIUSER;
      ALTER SCHEMA $AMBARISCHEMA OWNER TO $AMBARIUSER;
      ALTER ROLE $AMBARIUSER SET search_path to ‘$AMBARISCHEMA’, 'public';
    • Where $AMBARIUSER is the Ambari user name, $AMBARIPASSWORD is the Ambari user password, $AMBARIDATABASE is the Ambari database name and $AMBARISCHEMA is the Ambari schema name.
  2. Load the Ambari Server database schema.
    • You must pre-load the Ambari database schema into your PostgreSQL database using the schema script.
      # psql -U $AMBARIUSER -d $AMBARIDATABASE
      \i Ambari-DDL-Postgres-CREATE.sql;
    • Find the Ambari-DDL-Postgres-CREATE.sql file in the /var/lib/ambari-server/resources/ directory of the Ambari Server host after you have installed Ambari Server.
  3. When setting up the Ambari Server, select Advanced Database Configuration > Option [4] PostgreSQL and enter the credentials you defined in Step 2. for user name, password and database name.
