3.1. Using Oozie with Oracle
  1. On the Oozie Server host, install the appropriate JDBC .jar file.
    2. Select Oracle Database 11g Release 2 - ojdbc6.jar.
    3. Copy the .jar file to the Java share directory.
      cp ojdbc6.jar /usr/share/java
    4. Make sure the .jar file has the appropriate permissions - 644.
      # sqlplus sys/root as sysdba
      CREATE USER $OOZIEUSER IDENTIFIED BY $OOZIEPASSWORD;
      GRANT ALL PRIVILEGES TO $OOZIEUSER;
      QUIT;
    • Where $OOZIEUSER is the Oozie user name and $OOZIEPASSWORD is the Oozie user password.
