On the Ambari Server host, stage the appropriate JDBC driver file for later deployment.
Download the Oracle JDBC (OJDBC) driver from http://www.oracle.com/technetwork/database/features/jdbc/index-091264.html.
Select
Oracle Database 11g Release 2 - ojdbc6.jar
and download the file.Make sure the .jar file has the appropriate permissions - 644.
Execute the following command, adding the path to the downloaded .jar file:
ambari-server setup --jdbc-db=oracle --jdbc-driver=/path/to/downloaded/ojdbc6.jar
Using the Oracle database admin utility:
# sqlplus sys/root as sysdba CREATE USER $HIVEUSER IDENTIFIED BY $HIVEPASSWORD; GRANT SELECT_CATALOG_ROLE TO $HIVEUSER; GRANT CONNECT, RESOURCE TO $HIVEUSER; QUIT;
Where $HIVEUSER is the Hive user name and $HIVEPASSWORD is the Hive user password.
Load the Hive database schema.
You must pre-load the Hive database schema into your Oracle database using the schema script.
When using HDP 2.1 Stack:
sqlplus $HIVEUSER/$HIVEPASSWORD < hive-schema-0.13.0.oracle.sql
Find the
file in the/var/lib/ambari-server/resources/stacks/HDP/2.1/services/HIVE/etc/
directory of the Ambari Server host after you have installed Ambari Server.When using HDP 2.0 Stack:
sqlplus $HIVEUSER/$HIVEPASSWORD < hive-schema-0.12.0.oracle.sql
Find the
file in the/var/lib/ambari-server/resources/stacks/HDP/2.0.6/services/HIVE/etc/
directory of the Ambari Server host after you have installed Ambari Server.When using HDP 1.3 Stack:
sqlplus $HIVEUSER/$HIVEPASSWORD < hive-schema-0.10.0.oracle.sql
Find the
file in the/var/lib/ambari-server/resources/stacks/HDP/1.3.2/services/HIVE/etc/
