3.3. Using Oozie with PostgreSQL
    1. Install the connector.
      RHEL/CentOS/Oracle Linux
      yum install postgresql-jdbc*
      SLES
    2. Copy the connector .jar file to the Java share directory.
      cp /usr/share/pgsql/postgresql-*.jdbc3.jar /usr/share/java/postgresql-jdbc.jar
    3. Confirm that .jar is in the Java share directory.
    4. Change the access mode of the .jar file to 644.
    5. Execute the following command:
      ambari-server setup --jdbc-db=postgres --jdbc-driver=/usr/share/java/postgresql-connector-java.jar
      echo "CREATE DATABASE $OOZIEDATABASE;" | psql -U postgres
      echo "CREATE USER $OOZIEUSER WITH PASSWORD '$OOZIEPASSWORD';" | psql -U postgres
      echo "GRANT ALL PRIVILEGES ON DATABASE $OOZIEDATABASE TO $OOZIEUSER;" | psql -U postgres
    • Where $OOZIEUSER is the Oozie user name, $OOZIEPASSWORD is the Oozie user password and $OOZIEDATABASE is the Hive database name.
