JDBC connector
When using the JDBC connector, you can choose between using a PostgreSQL, MySQL, Oracle, Hive, Db2 or SQL Server databases. Based on the connector type you choose, there are mandatory fields where you must provide the correct information.
- Template: jdbc
- Using either PostgreSQL, MySQL, Oracle, Hive, Db2 or SQL Server as databases. When you use the JDBC connector, you must specify the JDBC database which are going to be used for the connection.
