developing spark applicationsPDF version
Using custom libraries with Spark
Spark comes equipped with a selection of libraries, including Spark SQL, Spark Streaming, and MLlib.
If you want to use a custom library, such as a compression library or Magellan, you can use one of the following two spark-submit script options:
  • The --jars option, which transfers associated .jar files to the cluster. Specify a list of comma-separated .jar files.
  • The --packages option, which pulls files directly from Spark packages. This approach requires an internet connection.
For example, you can use the --jars option to add codec files. The following example adds the LZO compression library:
spark-submit --driver-memory 1G \
    --executor-memory 1G \
    --master yarn-client \
    --jars /usr/hdp/2.6.0.3-8/hadoop/lib/hadoop-lzo-0.6.0.2.6.0.3-8.jar \
    test_read_write.py
For more information about the two options, see Advanced Dependency Management on the Apache Spark "Submitting Applications" web page.
