CUDA Engine - Technical Preview
To make it easier for users to get started with using GPUs on CDSW, the Cloudera engineering team is working on a new custom engine that comes enabled with CUDA out of the box.
Previously, users were expected to build their own CUDA engine.
Compatibility Information
The first version of this engine is built on top of CDSW base engine:13 and ships with CUDA 10.1. It has been tested with CDSW 1.8.x.
Custom Engine | CDSW | NVIDIA Driver |
cuda-engine:10 - Based on CDSW engine:13 - Ships CUDA 10.1 |
1.8.x |
418.39 (or higher) |
