Adding Cloudera Flow Library Registry Client
The Cloudera Flow Library Registry Client provides access to to Cloudera's exclusive Flow Library. These predefined flows can help you swiftly deploy solutions tailored to your specific needs in a wide range of use cases. Learn how to configure the Registry Client and check out flows from the library.
