Webhook connector
Due to the deprecation of JavaScript in Cloudera Streaming Analytics, the webhook connector can be used in SQL or through Python UDFs.
Example using the webhook connector in SQL
- Create a webhook table. Refer to Creating Webhook tables for more information.
Write into the webhook table the query's INSERT statement. Example:
insert into [***WEBHOOK TABLE***] select transactionId, ts, accountId, amount * 3 from [***SOURCE TABLE***] where amount % 2 != 0
Example using the webhook connector with Python UDFs
Create your UDF using the Cloudera SQL Stream Builder UI. Example:
from pyflink.table.udf import udf from pyflink.table import DataTypes from pyflink.table import Row @udf(result_type=DataTypes.ROW([ DataTypes.FIELD("transactionId", DataTypes.STRING()), DataTypes.FIELD("ts", DataTypes.STRING()), DataTypes.FIELD("accountId", DataTypes.STRING()), DataTypes.FIELD("amount", DataTypes.STRING()) ])) def udf_function(transactionId, ts, accountId, amount): if amount % 2 != 0: processed_amount = amount * 3 return Row(str(transactionId), str(ts), str(accountId), str(processed_amount))- Create a webhook table. Refer to Creating Webhook tables for more information.
Write into the webhook table using the UDF in the query's WHERE statement. Example:
INSERT INTO [***TABLE NAME***] SELECT transactionId, ts, accountId, amount FROM ( SELECT transaction(transactionId, ts, accountId, amount) FROM [***TABLE NAME***]" ) AS udf_results WHERE transactionId IS NOT NULL AND ts IS NOT NULL " AND accountId IS NOT NULL " " AND amount IS NOT NULL", destinationName, sourceName);
