Using Terms in Data Catalog
You can use the Asset Details page in Data Catalog to add or modify “terms” for your selected assets.
A new widget called “Terms” is available in the Asset Details page. You can define rich glossary vocabularies using the natural terminology (technical terms and/or business terms). To semantically relate the term(s) to each other. And finally to map assets to glossary terms(s).
You can assign terms with entities, search for entities, filter entities by glossary term(s), and also search for entities by using associated term(s).
