You can use this Getting Started use case to get familiar with the most simple form
of running a SQL Stream job.
The Getting Started contains the basic steps of running a SQL Stream job. When
executing the job, you do not need to select a sink as the results are displayed in
the browser. SQL Stream Builder provisions a job on your cluster to run the SQL
queries. You can select the Logs tab to review the status of
the SQL job. As data is returned, it shows up in the Results
tab.
Select SQL Stream Builder from the list of services.
Open a project from the Projects page of Streaming SQL
Console.
Select an already existing project from the list by clicking the
Open button or Switch button.
Create a new project by clicking the New Project
button.
Import a project by clicking the Import button.
Click next to Jobs from the
Explorer.
Select New Job > Create.
The SQL Editor for the created job opens in a tab.
Select datagen from the
Templates.
The CREATE TABLE statement is imported to the SQL
window.
Add a SELECT query to the SQL window after the datagen
template.
SELECT * FROM <table_name>
Click Execute.
You can see the generated output on the Results
tab.
