Adding Schema Registry as Catalog
You need to add Schema Registry as a Catalog using the Streaming SQL Console in SQL Stream Builder (SSB) to use Schema Registry with Flink DDL.
- Make sure that you have Schema Registry service on your cluster.
- Make sure that you have the right permissions set in Ranger.
