Flink SQLPDF version
Flink DML
Flink SQL supports Data Manipulation Language (DML) statements to manipulate the data itself with adding, deleting or modyfing.
The following table summarizes the supported DML statements in SQL Stream Builder:
DML Description Option
INSERT INTO Inserting query results into a specified table.
  • Inserting columns or values into a table
  • Adding OVERWRITE to overwrite the existing data in the table
