Stopping, restarting and editing SQL jobs
As a SQL Stream job processes streaming data, you need to stop the job to finish the process. You can restart a SQL Stream job after stopping it. In case you need to update or change the configurations that you have set for a SQL Stream job, you can restart it. You can navigate through the job life cycle using the Streaming SQL Console.
Stopping a SQL Stream job
- Stopping job from Compose page
- Select Console from the main menu.
By default, you are on the Compose page when selecting Console from the main menu.
- Click Stop under the SQL window.
- Stopping job from SQL Jobs page
- Click Console on the main menu.
- Select SQL Jobs tab.By default, Running Jobs are displayed on the SQL Jobs page.
- Click on the job you want to stop.
- You can further filter down the results, by directly searching for the job name in the Search field.
- Click Stop under Actions.
Restarting a running SQL Stream job
You can restart a running SQL job using the Restart button under the SQL window.
- Restarting job from SQL Jobs page
- Click on the job you want to restart.
- Click Edit Selected Job under the
Details tab.
The SQL job and its configuration is loaded in the SQL window on the Compose page.
- Click Restart.
Restarting a stopped SQL Stream job
- Select Stopped Jobs from the drop-down menu.
- You can further filter down the job list by searching for the job name, or locate
a specific job ID by prefixing your search with
id
- Click Edit Selected Job under the Details tab.
- Click on Execute.
Editing a SQL Stream job
- Edit any configuration of the selected SQL job.
You need to click on Advanced Settings to display more configuration of the SQL job.
- Click on Execute.
Deleting a SQL Stream job
You can delete a stopped SQL job from SQL Stream Builder on the SQL Jobs tab. By deleting the SQL job, you remove them from the list of stopped jobs.
The list of stopped jobs is diplayed on the SQL Jobs page.
- Click on Delete under Actions.
