Creating Materialized Views
After executing a SQL Stream job, you can set up the Materialized Views to have a snapshot of your queried data. You can use the URL Pattern from the Materialized View to visualize the generated data.
- Make sure that PostgreSQL is installed and configured to SQL Stream Builder (SSB) to create Materialized Views.
- You need to have a running SQL job on which you apply the Materialized Views configuration.
