Console Page
The Console page enables you to create your SQL jobs, and shows every SQL job related tabs, subtabs and audit tabs. By default the Compose tab is displayed with the SQL subtab, so you can easily create and execute your SQL queries.
- 1. Main Tabs
- Compose - By default, the Compose tab is selected on the Console.
- Tables - You can view, manage and add tables on this tab.
- Functions - You can add the User Defined Functions to your SQL query.
- History - You can review the history of submitted SQL queries.
- SQL Jobs - You can review the history of submitted SQL jobs.
