Engine Dependencies
This topic describes the options available to you for mounting a project's dependencies into its engine environment. Depending on your projects or user preferences, one or more of these methods may be more appropriate for your deployment.
- Installing Packages Directly Within Projects
- Creating a Customized Engine with the Required Package(s)
Directly installing a package to a project as described above might not always be feasible. For example, packages that require root access to be installed, or that must be installed to a path outside
/home/cdsw
(outside the project mount), cannot be installed directly from the workbench. For such circumstances, Cloudera recommends you extend the base Cloudera Machine Learning engine image to build a customized image with all the required packages installed to it.This approach can also be used to accelerate project setup across the deployment. For example, if you want multiple projects on your deployment to have access to some common dependencies out of the box or if a package just has a complicated setup, it might be easier to simply provide users with an engine environment that has already been customized for their project(s).
For detailed instructions with an example, see Configuring the Engine Environment.
- Managing Dependencies for Spark 2 Projects
With Spark projects, you can add external packages to Spark executors on startup. To add external dependencies to Spark jobs, specify the libraries you want added by using the appropriate configuration parameters in a spark-defaults.conf file.
For a list of the relevant properties and examples, see Spark Configuration Files.
- Managing Dependencies for Experiments and Models
To allow for versioned experiments and models, Cloudera Machine Learning executes each experiment and model in a completely isolated engine. Every time a model or experiment is kicked off, Cloudera Machine Learning creates a new isolated Docker image where the model or experiment is executed. These engines are built by extending the project's designated default engine image to include the code to be executed and any dependencies as specified.
For details on how this process works and how to configure these environments, see Engines for Experiments and Models.
