Model MetricsPDF version
Tracking model metrics without deploying a model
Cloudera recommends that you develop and test model metrics in a workbench session before actually deploying the model. This workflow avoids the need to rebuild and redeploy a model to test every change.
Metrics tracked in this way are stored in a local, in-memory datastore instead of the metrics database, and are forgotten when the session exits. You can access these metrics in the same session using the regular metrics API in the cdsw.py file.
The following example demonstrates how to track metrics locally within a session, and use the read_metrics function to read the metrics in the same session by querying by the time window.
To try this feature in the local development mode, use the following files from the Python template project:
  • use_model_metrics.py
  • predict_with_metrics.py
The predict function from the predict_with_metrics.py file shown in the following example is similar to the function with the same name in the predict.py file. It takes input and returns output, and can be deployed as a model. But unlike the function in the predict.py file, the predict function from the predict_with_metrics.py file tracks mathematical metrics. These metrics can include information such as input, output, feature values, convergence metrics, and error estimates. In this simple example, only input and output are tracked. The function is equipped to track metrics by applying the decorator cdsw.model_metrics.
@cdsw.model_metrics
def predict(args):
  # Track the input.
  cdsw.track_metric("input", args)
  # If this model involved features, ie transformations of the
  # raw input, they could be tracked as well.
  # cdsw.track_metric("feature_vars", {"a":1,"b":23})
  petal_length = float(args.get('petal_length'))
  result = model.predict([[petal_length]])
  # Track the output.
  cdsw.track_metric("predict_result", result[0][0])
  return result[0][0]
You can directly call this function in a workbench session, as shown in the following example:
predict(
{"petal_length": 3}
You can fetch the metrics from the local, in-memory datastore by using the regular metrics API. To fetch the metrics, set the dev keyword argument to True in the use_model_metrics.py file. You can query the metrics by model, model build, or model deployment using the variables cdsw.dev_model_crn and cdsw.dev_model_build_crn or cdsw.dev_model_deploy_crn respectively.
For example:
end_timestamp_ms=int(round(time.time() * 1000))
cdsw.read_metrics(model_deployment_crn=cdsw.dev_model_deployment_crn,
start_timestamp_ms=0,
end_timestamp_ms=end_timestamp_ms,
dev=True)
where CRN denotes Cloudera Resource Name, which is a unique identifier from CDP, analogous to Amazon's ARN.
