Model MetricsPDF version
Tracking metrics for deployed models
When you have finished developing your metrics tracking code and the code that consumes the metrics, simply deploy the predict function from predict_with_metrics.py as a model. No code changes are necessary.
Calls to read_metrics, track_delayed_metrics, and track_aggregate_metrics need to be changed to take the CRN of the deployed model, build or deployment. These CRNs can be found in the model’s Overview page.
Calls to the call_model function also requires the model’s access key (model_access_key in use_model_metrics.py) from the model’s Settings page. If authentication has been enabled for the model (the default), a model API key for the user (model_api_token in use_model_metrics.py) is also required. This can be obtained from the user's Settings page.
