Deployment scenarios
The application you want to build determines the Streaming Anaytics deployment process on CDP Private Cloud Base. You can choose between building either a DataStream application or a SQL streaming application.
You can deploy Streaming Analytics on Private Cloud Base depending on the application you want to build.
  • DataStream application using only Flink. In this case, you need to create a Flink application cluster.
  • SQL Streaming application using Flink with SQL Stream Builder. In this case, you need to create a Streaming SQL cluster.
You can use the following workflow to have an understanding of the deployment process:
