ML Runtimes Environment Variables List
The following table lists Cloudera Machine Learning environment variables that you can use to customize your project environments. These can be set either as a site administrator or within the scope of a project or a job.
Environment Variable Description
MAX_TEXT_LENGTH
Maximum number of characters that can be displayed in a single text cell. By default, this value is set to 800,000 and any more characters will be truncated.
Default: 800,000
SESSION_MAXIMUM_MINUTES
Maximum number of minutes a session can run before it times out.
Default: 60*24*7 minutes (7 days)
Maximum Value: 35,000 minutes
JOB_MAXIMUM_MINUTES
Maximum number of minutes a job can run before it times out.
IDLE_MAXIMUM_MINUTES
Maximum number of minutes a session can remain idle before it exits.
Default: 60 minutes
Per-Engine Environmental Variables: In addition to the previous table, there are some more built-in environmental variables that are set by the Cloudera Machine Learning application itself and do not need to be modified by users. These variables are set per-engine launched by Cloudera Machine Learning and only apply within the scope of each engine.
CDSW_PROJECT
The project to which this engine belongs.
CDSW_ENGINE_ID
The ID of this engine. For sessions, this appears in your browser's URL bar.
CDSW_MASTER_ID
If this engine is a worker, this is the CDSW_ENGINE_ID of its master.
CDSW_MASTER_IP
If this engine is a worker, this is the IP address of its master.
CDSW_PUBLIC_PORT
A port on which you can expose HTTP services in the engine to browsers. HTTP services that bind CDSW_PUBLIC_PORT will be available in browsers at: http(s)://<$CDSW_ENGINE_ID>.<$CDSW_DOMAIN>. By default, CDSW_PUBLIC_PORT is set to 8080.
A direct link to these web services will be available from the grid icon in the upper right corner of the Cloudera Machine Learning web application, as long as the job or session is still running. For more details, see Accessing Web User Interfaces from Cloudera Machine Learning.
In Cloudera Machine Learning, setting CDSW_PUBLIC_PORT to a non-default port number is not supported.
CDSW_APP_PORT
A port on which you can expose HTTP services in the engine to browsers. HTTP services that bind CDSW_APP_PORT will be available in browsers at: http(s)://<$CDSW_ENGINE_ID>.<$CDSW_DOMAIN>. Use this port for applications that grant some control to the project, such as access to the session or terminal.
A direct link to these web services will be available from the grid icon in the upper right corner of the Cloudera Machine Learning web application as long as the job or session runs. Even if the web UI does not have authentication, only Contributors and those with more access to the project can access it. For more details, see Accessing Web User Interfaces from Cloudera Machine Learning.
Note that if the Site Administrator has enabled Allow only session creators to run commands on active sessions, then the UI is only available to the session creator. Other users will not be able to access it.
Use 127.0.0.1 as the IP.
CDSW_READONLY_PORT
A port on which you can expose HTTP services in the engine to browsers. HTTP services that bind CDSW_READONLY_PORT will be available in browsers at: http(s)://<$CDSW_ENGINE_ID>.<$CDSW_DOMAIN>. Use this port for applications that grant read-only access to project results.
A direct link to these web services will be available to users with from the grid icon in the upper right corner of the Cloudera Machine Learning web application as long as the job or session runs. Even if the web UI does not have authentication, Viewers and those with more access to the project can access it. For more details, see Accessing Web User Interfaces from Cloudera Machine Learning.
CDSW_DOMAIN
The domain on which Cloudera Machine Learning is being served. This can be useful for iframing services, as demonstrated in Accessing Web User Interfaces from Cloudera Machine Learning.
CDSW_CPU_MILLICORES
The number of CPU cores allocated to this engine, expressed in thousandths of a core.
CDSW_MEMORY_MB
The number of megabytes of memory allocated to this engine.
CDSW_IP_ADDRESS
Other engines in the Cloudera Machine Learning cluster can contact this engine on this IP address.
