Cloudera Documentation
Using Apache FlinkPDF version
Flink application example
The following is an example of a Flink application about a streaming window word count that counts worfs from a web socket in five second windows.
import org.apache.flink.api.common.functions.FlatMapFunction;
import org.apache.flink.api.java.tuple.Tuple2;
import org.apache.flink.streaming.api.datastream.DataStream;
import org.apache.flink.streaming.api.environment.StreamExecutionEnvironment;
import org.apache.flink.streaming.api.windowing.time.Time;
import org.apache.flink.streaming.api.windowing.assigners.TumblingProcessingTimeWindows;
import org.apache.flink.util.Collector;
public class WindowWordCount {
    public static void main(String[] args) throws Exception {
        StreamExecutionEnvironment env =
            StreamExecutionEnvironment.getExecutionEnvironment();
        DataStream<Tuple2<String, Integer>> dataStream = env
            .socketTextStream("localhost", 9999)
            .flatMap(new Splitter())
            .keyBy(value -> value.f0)
            .window(TumblingProcessingTimeWindows.of(Time.seconds(5)))
            .sum(1);
        dataStream.print();
        env.execute("Window WordCount");
    public static class Splitter
        implements FlatMapFunction<String, Tuple2<String, Integer>> {
        @Override
        public void flatMap(String sentence,
                            Collector<Tuple2<String, Integer>> out)
            throws Exception {
            for (String word: sentence.split(" ")) {
                out.collect(new Tuple2<String, Integer>(word, 1));
