Data types for Kafka connector
When reading data using the Kafka table connector, you must specify the format of the
incoming messages so that Flink can map incoming data to table columns
properly.
JSON format The JSON format enables you to read and write JSON data. You must add the JSON dependency to your project and define the format type in CREATE table to JSON.CSV format The CSV format allows your applications to read data from, and write data to different external sources in CSV. You must add the CSV dependency to your project and define the format type in CREATE table to CSV.Avro format The Apache Avro format enables you to read and write Avro data. You must add the Avro dependency to your project and define the format type in CREATE table to Avro. You also need to specify the fields of the Avro record within the table.Schema Registry formats You can avoid defining the Avro or JSON schema for Kafka table sources and sinks, when the schema is stored in Cloudera Schema Registry.
