Enabling Flink DEBUG logging for SQL Stream Builder
You can review the log text files of the Flink jobs behind SQL Stream Builder (SSB) when an error is detected during the processes. When you set the log level of Flink to DEBUG, you can easily trace the log file for errors.
A log file is created about every Flink process that contains messages for the different events happening in the given process. You can use these log files to solve the errors and problems that can occur during SSB and Flink processes. You can access the Flink logs using the Flink Dashboard.
