Kudu with Flink
Apache Kudu is an analytic data storage manager. The data is stored in tables, which makes Kudu one of the suitable sinks for Flink to have analytical application solutions.
You can read Kudu tables into a DataStream using the KuduCatalog with Table API or using the KuduRowInputFormat directly in the DataStream. The difference between the two methods is that when using the KuduRowInputFormat, you need to manually provide information about the table.
For more information about the Kudu sink in DataStream API, see the official documentation.
