Using CEMPDF version
Connecting components in CEM
After you add processors and other components to the canvas of the Cloudera Edge Management (CEM) UI and configure them, the next step is to connect them to one another. This is accomplished by creating a connection between each component.
  1. Hover the mouse over a component.
    An arrow appears as shown in the following image:
  2. Drag the arrow from one component to another until the second component is highlighted, then release the mouse.
    A Create Connection dialog appears as shown in the following image:
    The dialog allows you to choose the Source Relationships that must be included in the connection. At least one relationship must be selected. If only one relationship is available, it is automatically selected.
  3. Select CREATE to create the connection.
