OperationsPDF version
Managing Datasets
You can view, create, edit, and delete Datasets.
On the Data Catalog menu, click Datasets to view all the datasets.
On the Datasets page, enter a search string in the search box to view all asset collections with names that contain the search string.
You can filter Datasets and view Dataset with the tags. Select the tag from the drop down list or enter the tag in the filter box. Any Dataset with the filter tag assigned to a column will appear in the filter results.
