OperationsPDF version
Viewing Data Assets
The Data Asset Overview page displays all the Apache Atlas metadata associated with a particular data asset.
The Data Asset Overview page displays:
Asset properties: Displays properties information relevant to asset type, like in case of Hive table - Number of rows, number of columns, number of partitions, and the owner.
From the Data Catalog search page, click to select a data asset.
The Asset Overview window opens.
The following matrix captures the supported fields for different asset types:
Asset Type Lineage Tagging Access Metrics Schema Policy Audit Atlas Punch out
Hive DB Not Supported Yes Not Supported Not Supported Yes Yes Yes
Hive Table Yes Yes Yes Yes Yes Yes Yes
Hive Column Yes Yes Not Supported Not Supported Yes Yes Yes
Hbase Namespace Yes Yes Not Supported Not Supported Yes Yes Yes
Hbase Table Yes Yes Not Supported Yes Yes Yes Yes
Hbase Column Family Yes Yes Not Supported Not Supported Yes Yes Yes
impala_process Yes Yes Not Supported Not Supported Not Supported Not Supported Yes
impala_column_lineage Yes Yes Not Supported Not Supported Not Supported Not Supported Yes
impala_process_execution Yes Yes Not Supported Not Supported Not Supported Not Supported Yes
ML_Project Yes Yes Not Supported Not Supported Not Supported Not Supported Yes
ML_Model_Build Yes Yes Not Supported Not Supported Not Supported Not Supported Yes
ML_Model_Deploy Yes Yes Not Supported Not Supported Not Supported Not Supported Yes
rdbms_db Yes Yes Not Supported Not Supported Not Supported Not Supported Yes
rdbms_column Yes Yes Not Supported Not Supported Not Supported Not Supported Yes
rdbms_foreign_key Yes Yes Not Supported Not Supported Not Supported Not Supported Yes
rdbms_index Yes Yes Not Supported Not Supported Not Supported Not Supported Yes
rdbms_instance Yes Yes Not Supported Not Supported Not Supported Not Supported Yes
rdbms_table Yes Yes Not Supported Not Supported Not Supported Not Supported Yes
spark_process Yes Yes Not Supported Not Supported Not Supported Not Supported Yes
spark_application Yes Yes Not Supported Not Supported Not Supported Not Supported Yes
spark_column Yes Yes Not Supported Not Supported Not Supported Not Supported Yes
spark_column_lineage Yes Yes Not Supported Not Supported Not Supported Not Supported Yes
spark_db Yes Yes Not Supported Not Supported Not Supported Not Supported Yes
spark_ml_directory Yes Yes Not Supported Not Supported Not Supported Not Supported Yes
spark_ml_model Yes Yes Not Supported Not Supported Not Supported Not Supported Yes
spark_ml_pipeline Yes Yes Not Supported Not Supported Not Supported Not Supported Yes
spark_process_execution Yes Yes Not Supported Not Supported Not Supported Not Supported Yes
spark_table Yes Yes Not Supported Not Supported Not Supported Not Supported Yes
