Kudu catalog
You can add Kudu as a catalog in Flink SQL by adding Kudu dependency to your project, registering the Kudu table in Java, and enabling it in the custom environment file.
The Kudu connector comes with a catalog implementation to handle metadata about your Kudu setup and perform table management. By using the Kudu catalog, you can access all the tables already created in Kudu from Flink SQL queries.
The Kudu catalog only allows to create or access existing Kudu tables. Tables using other data sources must be defined in other catalogs, such as in-memory catalog or Hive catalog.
Maven
Dependency
<dependency>
<artifactId>flink-connector-kudu_2.12</artifactId>
<version>1.15.1-csa1.9.0.0</version>
</dependency>
The following example shows how to register and use the Kudu catalog from
Java:
String KUDU_MASTERS="host1:port1,host2:port2"
KuduCatalog catalog = new KuduCatalog(KUDU_MASTERS);
tableEnv.registerCatalog("kudu", catalog);
tableEnv.useCatalog("kudu");
tableEnv.listTables();
For more information about the Kudu connector and catalog, see the official documentation.
