Using Apache FlinkPDF version
In this example, you will use the Stateless Monitoring Application from the Flink Tutorials to build your Flink project, submit a Flink job and monitor your Flink application using the Flink Dashboard in an unsecured environment.
  1. Clone the simple tutorial from git:
    git clone https://github.com/cloudera/flink-tutorials.git
  2. Access the simple tutorial folder:
    cd flink-tutorials/flink-simple-tutorial
  3. Build your Flink project using maven:
    mvn clean package
  4. Upload the Flink project to your cluster.
    scp <location>/flink-stateful-tutorial-1.2-SNAPSHOT.jar <your_workload_username>@<master_node_FQDN>:.
    Password:<your_workload_password>
  5. Run the Flink application:
    flink run -d -p 2 -ynm HeapMonitor target/flink-simple-tutorial-1.2-SNAPSHOT.jar
  6. Navigate to Management Console > Environments, and select the environment where you have created your cluster.
  7. Select the Streaming Analytics cluster.
  8. Click Flink Dashboard from the services.
    The Flink Dashboard opens in a new window.
  9. Click Task Manager on the left side menu.
  10. Monitor your Flink application under logs.
